Results 1 to 20 of 23
Thread: 2020 2.7 ecoboost Max Boost possible?
    Feb 2019
    38
    Hey all so I have a bone stock 2020 2.7 ecoboost. I did some initial scans yo see the stock performance of the truck. While fun to drive data shows it could be better. So I understand I mostly want to stay in torque management to pull ou those few extra horsepower. But Im comimg from Dodge Hemi tuning to here and am not confident yet even changing parameters.
    But what I would like to know for my piece of my mind is how much boost can these stock turbos safely take? Im asking as it is already producing from what Ive seen so far upto 18.3 pounds of boost. So if my assuming is right and please correct me if im wrong but changing the torque management tables will allow me to command more torque which in turn would up the boost yes? If this is the case and say max boost is around 20 pounds should I just stay away until I upgrade these turbos?
    May 2018
    44
    Quote Originally Posted by CannaGeneticsBank View Post
    Im up to 24psi, im running full E85 and seeing cylinder pressure limit so id say im close to the maximum.
    Feb 2019
    38
    Thank you sir
    Jul 2016
    Fort Worth/Dallas Texas
    29
    I have a 2015 2.7. I typically see ~ 24 psi depending on the conditions.
    Would you mind posting your stock file?
    I tried upping the boost that particular way and didn’t get any luck, I know you have the mess with the canister pressure and wastegate duty cycle also tried but no luck. Hopefully someone can chime in to help
    May 2018
    44
    Quote Originally Posted by Eduardoc22 View Post
    I tried upping the boost that particular way and didn?t get any luck, I know you have the mess with the canister pressure and wastegate duty cycle also tried but no luck. Hopefully someone can chime in to help
    ok ill give you the seasonings and you determine the spicyness.
    change pressure limits/overspeed limits/temperature limits/overspeed
    change canister pressure/change wastegate feedback
    change map max/calc map max
    change throttle inlet pressure/underboost fault time
    exhaust flange temp/exhaust manifold temp/cat temp
    temp based cutoff
    fuel enrichment pedal/WOT lambda
    max retard/max advance/max load
    torque monitoring/map max pressure monitoring
    torque limit timer/max torque/max torque OP1/max torque 2/max torque op2/max torque 3/max torque op3
    lspi reduction LO/HI/NOM/comb stability limits
    driver demand desired torque
    Quote Originally Posted by thegeneralLee View Post
    temp based cutoff
    I’ve done it all, I need help with the canister pressure and wastegate. Which the add and which to subtract. I’ll post my tune file tomorrow
    May 2018
    44
    I?ve done it all, I need help with the canister pressure and wastegate. Which the add and which to subtract. I?ll post my tune file tomorrow
    Aight den
    Advanced Tuner skylinedan's Avatar
    Sep 2019
    Toledo Ohio
    227
    Try tuning a 2017 Fusion Sport, the damn waste gate actuators are run backwards. You apply vacuum to them to open the gates
    Jul 2017
    27
    all 2.7 engines use vacuum reference instead of positive pressure for wastegate control
    Jul 2017
    27
    I'm willing to share my 2.7 e85 file with you if you are looking for a big power increase. you MUST use full e85 for this tune. Reply back and let me know
    Quote Originally Posted by Jace Jackson View Post
    post it you dont mind
    Aight den
    Here is the latest i have of mine, which i didnt have any luck with increasing boost.
    Jul 2017
    27
    E85 Tune 3.hpt
    I have attached the E85 tune for you
    Jul 2017
    27
    Quote Originally Posted by jace jackson View Post
    E85 Tune 3.hpt
    i have attached the e85 tune for you
    note: Vcm beta is required to open this file
    E85 Tune 3.hpt
    Thanks, what were the main parameters you changed to increase boost?
    Jul 2017
    27
    Go through the tune, and compare to your stock tune. This will show you what has changed and what is different. It will give you a starting point to learn what needs changed.
    I have a 2019 myself and looking to tune it for 93, is there a good place to start with these? I was going to just log it on 93 then go from there.
    Sep 2019
    Toledo Ohio
    227
    I got a 26 lb reading the other day and 525 lbs of torque, I went back and cut a few things, LOL. 26 is a bit much, I do wonder how close that 525 is to being real though.
