Is it safe to turn this feature completely off?
https://forum.hptuners.com/showthrea...st-knock-issue
in the 350 LS1B days we always turned this off.
Just wanted some opionions.
most people do because when you have headers your knock sensor becomes sensitive.
this is how I have mine tuned (LSA) based on some feedback I have received from other tuners. It is reduced from 0.012 - 0.048 air flow and active only in V8 mode.
0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0
0 0 2 4 4 4 4 4 4
2012 CTS-V BDT, Auto, Every Option | Lingefelter 2.55" UP | DW65 Injectors | C&R HX | Pierburg CWA100 | 90mm TB | Airaid CF Intake with Green Filter | Lingefelter 160deg T-Stat | 534whp/503tq
2002 C5 Z06 Quick Silver, AR Headers, Borla Axle Back, A&A Kit
Bust knock isn't actually the Knock Sensor detecting knock. It is only the ECU using it to pull timing on large airmass changes where Knock Retard is more likely to occur. Personally when I tune cars I usually just cut the allowed burst knock value in half vs completely disabling because most of them are street cars. But for a drag setup I would disable it completely at the track.
Nice. Just wanted to make sure that hadn't changed.
Thanks for the responses.
