Results 1 to 7 of 7
Thread: 08 Magnum Check Engine after writing tune.
    So I just wrote a tune for a friend's 08 Magnum 6.1 and afterward, the check engine light is on. Tried clearing codes but it didn't go off. It's saying it lost communication with TCM, etc. Any help is appreciated. I've read where sometimes a particular fuse has to be pulled.
    Advanced Tuner RandomEnthusiast's Avatar
    Feb 2016
    Texas
    333
    Same problem I had when I flashed a 14 challenger. It's normal. It should clear on its own or pull the battery. I've confirmed both methods. Or pull pcm/tcm fuse and leave it out for a while.
    May 2015
    1,908
    That doesn't seem normal. Looks like you might have flashed it without the TCM portion of the tune. Try to verify in the read tune you read the TCM, and then are flashing it correctly (select correctly in the drop down).
    HPT Employee Engineer@HPT's Avatar
    fecadefa
    615
    Don't forget to turn the ignition off for 15 seconds after every flash.
    Feb 2016
    Texas
    333
    I just reflashed that 14 challenger I had the other thread about 3 times in a row. Read that save new. Then flash. Key off 15 seconds between flashes. Codes come up everytime. But within 5 miles they go away. Everytime. I've asked a guy who works at the dodge dealer locally and he says that they get similar codes everytime they update the pcm is what he told me. So I think it's normal. I only have access to one dodge at the moment. I'll report back if I see it anymore more when I start flashing other vehicles.
    Aug 2009
    Calibrating
    3,373
    I have an 08 300 5.7 liter that has a check engine light now too... I’ve tried unhooking battery, driving it, clear ECM and TCM dtcs snd still there!!
    Anyone have any ideas?
    Pretty frustrating not able to even see DTCs
    Mar 2018
    Illinois
    873
    Quote Originally Posted by Engineer@HPT View Post
    It says 10 seconds after the write. The one time I wrote to the PCM and forgot to cycle the ignition the dash chimed and the MIL light turned on.
