Page 3 of 3 FirstFirst 123
Results 41 to 42 of 42
Thread: Question about PE
  1. #41
    311
    Adjusting the alcohol table work out perfectly to hit my target commanded AFR. I didn't realize it blended between the two tables. I logged and made a couple hits this morning and it held steady at .87-.88. Thanks guys.
  2. #42
    Advanced Tuner Ghostnotes's Avatar
    Feb 2012
    Houston, TX
    471
    Quote Originally Posted by Ben Charles View Post
    2 things shops that’s send me tune work all over the world often get wrong... engine doesn’t go into PE quick enough (often times in boost rigs they will be making 4-5psi and still not be in PE..
    The other is below 2k rpms they have fuel wayyy to rich (stock converter sees this from a dig) this can be closer to stoich levels
    I might try to lean it out to see if it helps. My 4th and 5th gear pulls feel pretty good, but you made a point that makes sense to me to maybe lean it out further. I'm manual so if I do not drop gears and I load it up a little at lower rpms........
