Results 1 to 10 of 10
Thread: 5.7 2013 NN off - VE table absurd stft Values
    May 2018
    Germany
    590
    Turn OL off , baro learn and all th stuff.
    Fuel trims going wild in higher ranges...but why?
    VE tables shows up to 140 after correction.
    Anyone experience with this?
    new.hpl
    May 2018
    Germany
    590
    new air.hpt
    here is the tune from the log....
    May 2018
    Germany
    590
    Detected a small air leak.....lets see, what's next....
    May 2018
    Germany
    590
    I fixed the leak, but the scanner shows strange things.
    In the lower RPM it works fine.
    At 3600 RPM it goes up to high values like 100 in the mid range.
    Where did you find a VE table to start off with? I've been poking around for good initial values for a VE table but haven't found anything that I can use as of yet. Also have you seen any chances or improvements since you corrected the vacuum leak?
    Just as an update, I did find a video on Youtube that assists with tuning VE tables for GM's. I'm hoping that when I get to this point I'll be able to use a lot of the information from it where it applies.
    May 2018
    Germany
    590
    I started with ve table +20% to get it rich. now with the new intake the table is lower than stock....
    May 2018
    Germany
    590
    Still the same problem.....Do I have to DISABLE the VVT to get off ANN on 2013?
    Then I would get a camshaft without VVT ....Any Help?
    yes you have to completely disable nn and the vct to have any effect with your ve table.
    May 2018
    Germany
    590
    Thanks, but what more should I disable?
    NN = Off
    VVT = All set to disabled
    I think I try to set the Injectors first with WB, maybe the difference is too big to get correct VE.
