I have a 6.1 hemi ran fine before swapped a comp hrt stage 2 cam if it idles too long or sometimes when from drive to park or neutral will start idling high and lightning bolt would flash on cluster. and btw I'm new at this been watching a lot of videos and researching on here.
Probably won't work on your 2007 for the reasons iCanuk explains in that thread. Only thing alfa can do for you is probably throttle relearn if that is what is causing the lightening bolt on the dash to light up.
I have done throttle relearn still same issue. I been looking at other trans tune maps on here and limp mode rpm is set higher at 1k instead of 500 like I have will try copy and paste a trans tune from on here and see what happens.
thank you sir!!!
mods is only is vale springs intake catless straight pipe 6.1 hemi pretty much stock.
cam specs
Advertised Intake Duration: 273
Advertised Exhaust Duration: 279
Intake Duration at .050 Inch Lift: 220
Exhaust Duration at .050 Inch Lift: 230
Intake Valve Lift: 0.596
Exhaust Valve Lift: 0.582
Lobe Separation: 113
car does not go into limp mode anymore
