Results 1 to 9 of 9
Thread: What does "filter" do for a chart selected in "Chart Display Layout Editor"?
    Jun 2014
    Boulder, CO
    202
    There is a box in the VCM Scanner 4.6.3 labeled "filter" with the units of ms in the "Chart Display Layout Editor" for any selected chart item. This is *not* the filter function in the graphs. The value is zero for all my charts except when I added a AFR sensor, it defaulted to 100 ms. But changing that to zero seems to make no difference. What does that "filter" box control? Is it an averaging or update cadence control?
    Jun 2014
    Boulder, CO
    202
    So I guess no one knows?! In case it isn't clear, I attached a pic of the "filter" field in question...
    Feb 2020
    Metro Detroit Area
    263
    Its for filtering out transients, such as on and off the throttle. It waits that many milliseconds before data is recorded.
    Feb 2020
    Metro Detroit Area
    263
    And you should be using Lambda, its easier
    Jun 2014
    Boulder, CO
    202
    Quote Originally Posted by danmw2003 View Post
    Thanks for the reply! Agreed and I do use lambda in my graphs. I've set that "filter" value between 10 ms and 5000 ms w/o seeing any difference in displayed chart line when playing back a log. Since you mentioned "recording," is that filter only effective while recording a log, not in displaying a previously recorded log? Sorry if I'm beating a dead horse, just trying to learn as much as I can ;-)
    Jan 2014
    Australia
    1,978
    future filters only show when watching the log back, past filters work live, if u want to see where a filter is working or not just use the filter alone in a maths pid and it will show 1 or 0 if ur accepting data or ignoring data and u can overlay that in the chart v time to see where u are with the filter itself
    Jun 2014
    Boulder, CO
    202
    Thanks for that info on future vs. past filters. I understand and use those "expression-type" filters in my graphs. But the "filter" field in the *CHART display layout editor* accepts only a single numeric value, not an expression. That's why I asked my original question about that specific field. Sounds like it's simply a "past filter" smoothing (averaging) filter.
    Aug 2020
    335
    The chart display filter is only for the number displayed during live scanning.
    See post #2 - https://forum.hptuners.com/showthrea...isplay+filters
    Jun 2014
    Boulder, CO
    202
    Bingo!! Now that makes sense and answers my question! Thanks for linking off to that thread! I call this case closed.
