Results 1 to 6 of 6
Thread: first time tuning a subaru, new to tuning, need help
    Jun 2020
    north lewisburg, ohio
    I'm kinda lost, I cant get this thing to enrich when it comes into boost to save my life, please help me!
    Jun 2020
    soo, this has changed quickly, couldn't get an afr error table to read out to tune the MAF so I started adding to get my afr right and kept playing with it manually until we got good afr everywhere. 14s and 13s around town and I'm mid 11s at wot. soo still having a issue. I keep getting a fuel cut in 3rd and 4th up high while doing pulls. 1 and 2 no issue thing pulls hard and is making good power. ive got my fuel cut set to 30psi and am only running 19 and its still having issues. car has a up pipe, full catless exhaust, down pipe, aem intake, tial external waste gate that dumps to atmosphere, with a "13lb" spring in it, air pump delete too. I'm happy with the car and ready to deliver other than this cut. as soon as cut happens it throws a p0244. I had waste gate set to 0% due to over boosting badly. clearly the spring in the gate isn't a 13lb spring. ill attach my tune and a log. ive set plug gap to .020 thinking maybe it was blowing spark out as well. no dice.
    stiOG.hpt
    BradsSTIlog.hpl
    Quote Originally Posted by nandfperformance View Post
    stiOG.hpt
    BradsSTIlog.hpl
    I don't have my MPVI2 on me at the moment so i can't view the tune file (I can look tomorrow though), but keep in mind the fuel cut pressure is an absolute pressure, not relative. That may or may not be your issue, i won't know until i look at the tune
    Nov 2020
    The front 02 sensor is not a wideband sensor so you will need to get one. What model car do you have
    Nov 2015
    41
    I had the same issue : banghead:
    stiOG.hpt
    BradsSTIlog.hpl
    Look at your desired boost table. It's set to 20 across the board. This is absolute pressure, so you're only commanding around 5.3 psi everywhere.
