Results 1 to 1 of 1
Thread: 09 cady going lean 1000 fic injectors
    Oct 2012
    gadsden al
    170
    09 ctsv cady 2.45 pulley reinforced brick fully built bottom fic 1000h injectors, got her out to do a base street after the built and i see the injector going to 80+% on the data log. pump is tuned and turned up for the fuel load. Got it on the dyno and ran fuel pressure check, its dropping out bad.drops to 30 psi stock system should be good to 800hp as far as i know i am probably rong. we also saw dl tq on the street jump to 640 every hit and only saw 560 on the dyno. even with pressure dropping down i was able to pull fuel out and clean it up. we saw 12.0 afr. on the street i am seeing a tone more load. you will see 23* of timing this on 116 fuel and knock is not turned down at all. all that the injector are staying open way to long. i am sure i missed something.
