Hey guys, appreciate any help you can provide in advance.
I am moving to E85 on my Ls3 C6.
I have the alcohol tables ready and all the blend rates, etc.
What I am having trouble with is the injector data I am trying to swap in.
I have 54lb (but data looks like they're actually 50lb) ls3 style injectors from a flex fuel 6.2 - GM PN 12609749
I have the e38 tune read from a stock 6.2 flex fuel Esky, however my data is not matching up to the cells between my e38 in the c6 to the Cadillac.
Cadillac-
C6-
Now, I found a spreadsheet here, linked below, to figure out how to get these injectors to work and swap data cleanly between both style ecus.
Spreadsheet-
injector delta pressure inerpolator rev d1.xls
So what I did was try to figure out the 400kpa number from the Escalade. This cell is not there, but I tried to figured it out by plugging numbers into the sheet attached, which you will see - that is saved with my data, to have it match the 408 cell.
Is this correct?
Would I then say my 400kpa cell for the c6 should be 49.94799847 and run that same value how the C6 is setup from cells 128 to 400? Or do I copy the Esky and how it ramps?
Ramping new data like escalade-
Like C6 Data-
Again, I have no idea if this above data is correct, never done this before but did some digging and trying to learn.
Would I also change injector flow mult vs fuel flow? Anything else need to be changed?
Thank you guys for your help.
