Im looking to get more power out of this car. It seems the pedal is commanding about 410ft lbs at high rpm wot but the actual is about 306 seems to be allot of loss and I cant seem to find where.
Can someone point me in the right direction.
Your desired torque references indicated torque, not flywheel torque. So the 'actual' is just subtracting the accessory loads, friction, etc. But it is requesting full torque. Just shows you the lower/more accurate value.
