I have been beating my head against the wall for three plus days.
I have a 402CID engine, AFR heads 42# deatchwerks injectors.
2008 Corvette calibration on a PCM and a have tried multiple harnesses.
2008 Corvette Base.V1.hpt
Here is the tune I am using, I am out of ideas.
It is getting fuel, it has pressure, spark, again I am at the end of my rope.
Engine is on my engine run stand and waiting to startup to deliver.
Engine was primed and after it wouldn't start the first time I even pulled the front cover back off to be sure the cam was correctly installed, no issues.
The only thing I see is that it is commanding 3.91 AFR at the time I crank it, it just seems super rich. Plugs are wet after cranking, it is clearly getting gas, can't put my finger on the issue.
Any help is appreciated.
