Results 1 to 17 of 17
Thread: Issues with idle after lt4 supercharger install on 2017 silverado
    May 2020
    9
    Hello everyone. I have a bit of an issue that's driving me crazy. I have been working with Ben Charles on tuning my 2017 silverado 5.3 with an lt4 supercharger. Ben is doing a great job on the tune, but i have an idle issue that i can't seem to find a solution for. The truck just wants to idle high, between 1,300rpm and 1,500rpm in park, 850rpm-900rpm in drive. When in park, i tap the gas pedal and it will drop the idle to about 1,100rpm. But then it will slowly climb back up. The truck has an LT4 throttle body. I have tried everything and it just keeps idling high and throwing a CEL. I have done the factory relearn procedure- didnt work- no change, i have tried the throttle body clean on VCM scanner- didnt work- no change, I have switched back to my L83 throttle body- didnt work- no change. I have used carb cleaner to test for vacuum leaks around the intake couplers, and around the intake manifold runners. I just want to make sure i havent missed something. Ben has tried multiple different tunes, with no change happening. Any help would be appreciated. The codes its throwing are as follows:
    P0121- Throttle/Pedal position sensor A circuit range/performance
    P0507- Idle air control system RPM higher than expected
    P1101- Mass airflow sensor out of self test range
    Aug 2010
    Detroit, MI
    932
    I saw you post about that on pt.net. Have him post the file. We've been discussing torque modeling a lot here recently...this would be a good guinea pig example for virtual torque calibration.
    May 2020
    9
    I’m not sure what pt.net is. I haven’t posted anywhere but here.
    May 2020
    9
    Performancetrucks.net?
    Aug 2010
    Detroit, MI
    932
    Quote Originally Posted by LT4pwrdTexed View Post
    Ah, well then someone else has the same exact build and a similar name. Disregard
    311
    Quote Originally Posted by smokeshow View Post
    I thought the same exact thing.
    May 2020
    9
    Oh ok, haha! What are the odds
    Aug 2009
    Calibrating
    3,373
    Just seeing this! Sent ya an email! Idle set point is at 650 roughly warm idle and we are at roughly 850-900 rpms with map kpA about 10 kpA too high and ETC at 3.x percent with timing at a low 1-2 degrees (which the ECM is doing its best to pull out spark/tq to lower idle speed..
    I believe we have a small vac leak that’s introduced in the system by the KPA/throttle/spark reading...
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Aug 2010
    Detroit, MI
    932
    Quote Originally Posted by Ben Charles View Post
    Post it up here! And the data
    Aug 2009
    Calibrating
    3,373
    I do a lot of Programs using the LT4 on many transplant setups (3 this week) that individuals pay for.. not fair for anyone just to grab that work for free and use it!
    You seem to be a seasoned calibrator not worries about you... but many would use that work and profit off it.
    14 Gen 5 Viper
    Aug 2010
    Detroit, MI
    932
    Yeah I get it. I'll have to go solicit someone's freshly modded vehicle to use as an example lol.
    May 2020
    9
    I believe we have a small vac leak that?s introduced in the system by the KPA/throttle/spark reading...
    I got it!
    May 2020
    9
    We got it! Turns out, im and idiot and ran the LT4 pcv port on the bottom of the blower back into the intake. Rookie mistake by me! Ben Charles was the one that figured it out. Thanks Ben.
    Aug 2010
    Detroit, MI
    932
    Oh man, I thought he was joking about a vacuum leak. lol
    Aug 2009
    Calibrating
    3,373
    Glad to help... when people work with me they typically get much more then just a program, they get knowledge and information with it. So for reference now we are at 9 percent throttle, mid teens timing, map KPA around 37, commanded and desired AFR match, MAF G/sec follows what I speculated and fuel trims within few perfect at idle
    14 Gen 5 Viper
    Me and Ben have been working on my lt4 setup and I had a vac leak as well that caused the same issue turned out i missed the little nipple below the actuator. I was going to use it for boost gauge but forgot to cap it since I haven't installed the gauge yet lol.
    May 2020
    9
    Lol, the smallest things cause issues when modding. It’s nuts.
