I have a turbo gen 3 5.3 (P01) that I'm tuning and looking for a little help on something. It was previously tuned and they put in a "Safety Net" where after 8psi it would dump fuel and pull timing using the BE EQ Ratio and AFR Timing Advance tables. I am moving more towards 12 to 13psi now and have removed this but still seems to be acting on the timing and air-fuel. I'm sure the rich condition is due to the VE table not being tuned past the 8psi range even with the BE EQ Ratio corrected but with the AFR Timing Advance tabled 0'd out, it still pulls up 0.5 degrees at higher boost levels. I'll attach the tune and a log if someone could double check things for me, I'd appreciate it. Thanks.
