Results 1 to 4 of 4
Thread: Knock retard
    Sep 2017
    736
    Knock retard
    Is there an acceptable amount of knock/knock retard or is the goal to rid of it all?
    I get 1-3? of retard with an occasional spike between 2400 and 3600 and part throttle. Looking at old logs it tends to alway happen in the same rpm range.
    Recovery rate in the 2400-3600 range removes knock quicker so im assuming this is a common range for knock to occur.
    Thanks guys
    1997 30th SS. Torqhead 24x, TFS heads, 223/235 cam, 4l80e, S60 D1SC 14psi
    13,565
    I wouldn't even bat an eye with that. The knock you see isn't hurting anything and won't be noticed at all.
    Sep 2017
    736
    Thank you. To add to this i just figured out why i was never showing knock. It was more of a scanner issue than not getting knock at all. So once i figured out the scan all my logs show knock in relatively the same rpm/cylinder airmass range.
    So to say that its not noticeable is 100% bc i didnt even know it was happening and it didnt bother me then so why should it now.
    Sep 2017
    736
    Pulled 1 degree across the table and it seemed to get rid of 90-95% of the knock with a few degrees popping up here and there.
