Page 3 of 3 FirstFirst 123
Results 41 to 43 of 43
Thread: Gen 3 coyote comp cams
  1. #41
    Oct 2016
    Poland
    1,729
    No not that simple. You will need to make it working on single MP.
    I did something similar a while ago, old Cobra engine running on F150 coyote PCM.
  2. #42
    Aug 2023
    5
    Just a note, I just completed an install of the Stage 2 NSR Gen 3 cams in my 2018 Mustang GT race car and they are amazing. On 93 we made 484 RWHP@7300 and a peak Torque of 431 ft/lbs@5000, with over 400 ft/lbs from 4200-6200 rpm, and over 450 HP from 5500-7700 rpm. These are SAE5 numbers, for a road race car these broad power numbers are amazing. One note about installation that I haven't seen mentioned and will definitely cause oil pressure loss is the installation of the exhaust cam seals on the #1 journal. Ford part number for these is FT4Z6C262A, there are two per camshaft, exhaust side only. Hope others have had successful installs.
    Steve
  3. #43
    Quote Originally Posted by SteveEspo View Post
    Steve
    So are you saying not to run the exhaust cam seal? Just trying to clarify.
