trouble when lifting throttle while rolling or clutch return to idle
2003 C5Z V2 si trim t56
I've had HP tuners for about a year. I had an issue with hanging idle and made the adjustments to throttle cracker 85/84 and it fixed that issue.
When rolling, if I press the clutch and lift the throttle it returns and passes idle (825) dips to 500-600 and recovers. Once in a while it stalls.
I have skewered the net and did some changes that others have been able to correct this. I've had no luck.
your logging some irrelevant paramaters. You should post up a tune and log stit, ltit, throttle follower, throttle cracker, injector pw on both banks. Also what is up with your wideband reading.
Thanks for the info. I'll work on getting that info. Its a bit overwhelming
Haven't been able to get the WB reading correctly. I have 5 volt signal. AEM 0334. I had to add the pin and wire.
