Results 1 to 9 of 9
Thread: is my ecm taking a crap?
    Tuner Onomoto's Avatar
    Aug 2018
    Ohio
    120
    So short and sweet i had a couple of issues this past week. Found a faulty maf that was giving me grief along with a bad coil pack.
    But i cant figure out why its doing what is is now. It started after a weekend racing and got worse. discovered i cooked the maf because i left the key in the on position to use the scanner to run the fans between runs because the settings wont let me do it with the key off. corrected that now it randomly drops spark rpms shoot up on the scanner but the car actully wants to die. i am feeling that the ecm is on its last leg and starting to flake out. yes i know i have negative timing. wanted to see if i could do a pop pop pow, tune
    2001 monte carlo swapped l67 on e85
    XP cam
    gen5 m90
    NorthStar throttle body
    speed daddy headers 3inch exhaust
    3.0 pulley
    lq4 maf
    cold air filter behind bumper
    60 lb injectors
    Aug 2018
    Ohio
    120
    took a longer log file. most of the time it was idling out of gear. i noticed that the ecm is commanding 15.7 afr and going into open and closed loop.
    XP cam
    gen5 m90
    3.0 pulley
    lq4 maf
    60 lb injectors
    Aug 2018
    Ohio
    120
    Noticed the 02 sensor is staying rich a lot. Then the open loop follows.
    XP cam
    gen5 m90
    3.0 pulley
    lq4 maf
    60 lb injectors
    13,576
    Looks like it's cycling through a cat test that HP Tuners can't disable if I had to guess at it. I know the much older DHP Tuner can disable that but you'd need own it or know someone with one to disable it. This problem happens on the 2001+ computer because of changes in emissions. The older 1997-2000 don't have the cat test.
    There might be a work around with installing the rear o2 sensor in the exhaust is spacing the sensor out enough to not trip a P0420 code for under performing cat.
    Aug 2018
    Ohio
    120
    5fpd. That might be true but I have never seen it before on past log files. Plus the way the rpms shoot up on the log is questionable because when it does that the engine mis,s. Along with other problems I will do a hard pull and right when it goes to shift on the 1-2 its like the ignition is switched off and the engine dies. It doesn't always start right back up. I pulled the plugs and they don't look to hateful taking the injectors tomorrow to have them tested.
    XP cam
    gen5 m90
    3.0 pulley
    lq4 maf
    60 lb injectors
    Advanced Tuner ZeroBoostBuick's Avatar
    Aug 2008
    S.W. Ontario Canada
    322
    I've seen them command higher than 14.7 for several seconds right after start up when the engine is already fully warmed up.
    Aug 2018
    Ohio
    120
    I have a concern about how the rpms spike up with no throttle input.
    XP cam
    gen5 m90
    3.0 pulley
    lq4 maf
    60 lb injectors
    Aug 2018
    Ohio
    120
    Had the injectors flow tested and cleaned. Replaced plugs and 02 sensor. Runs like a champ now
    XP cam
    gen5 m90
    3.0 pulley
    lq4 maf
    60 lb injectors
    Aug 2008
    S.W. Ontario Canada
    322
    Damn, that's good to hear.
