Can anyone tell me why my injector pulse goes up to 499ms as soon as my engine fires up? Floods out immediately with plugs soaked with gas
Stock tune with vats removed, converted to cable throttle, tables adjusted for injectors. I also bumped up the injector flow rate 25% higher, because it wouldnt even fire at the correct rate.
Lq4
milled 317 heads
Texas speed 228r cam
50lb delphi flex fuel injectors
long tubes
