Results 1 to 2 of 2
Thread: rich idle someone help
    Jun 2018
    12
    can some look at my file and tell what im doing wrong
    13,565
    What is going on with your timing?
    This thing doesn't need to idle at 32 degrees, it should be more like 18-20 degrees and the huge timing swings are not helping you. Like in first log posted.
    Make sure your fuel pressure is staying steady and often on vehicles with large injectors you may need to cut the min fuel milligrams table down some so stop rich idle.
