Results 1 to 16 of 16
Thread: 18 Lt1 questions
    Apr 2007
    1,104
    18 Lt1 questions
    Two quick questions as I have not dove this far into the Lt stuff. MSD manifold volume for the LT1 setup. Also being paired with the 103mm tb. Same changes apply to this as a gen 4 on the ETC scaler?
    93 Ranger. 5.3 D1X. 1069hp.
    Apr 2007
    1,104
    so, no one knows? ::sadpanda::
    what is the msd manifold volume? anyone?
    Aug 2009
    Calibrating
    3,378
    Manifold volume will need to be increased (I have not measured (almost impossible with runners inside with pleunum to measure with liquid.. increase it some but nothing crazy..
    ETC scaler I don’t believe is as important on the gen 5 ECu but I still change this value out of good practice in my opinion.. I’ve left it stock and moved it all the way to 8,000 with no real difference however
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Apr 2007
    1,104
    So the ect scaler doesn't play hell with the air flow tables like the gen 4 stuff? interesting.
    Trying to find the volume is proving to be a pain in the ass.
    Apr 2007
    1,104
    the more digging i do into this, the more the scaler doesn't need to be changed per Nick williams. The manifold volume doesn't seem to be present in the newer ones. Unless it's hiding somewhere
    Aug 2009
    Calibrating
    3,378
    I’d be surprised if anyone knows...
    Increase manifold volume half to a full point that be very close just looking at the manifolds (even if you were to leave it stock it would be fine, I just like all models as accurate as possible)
    ETC scaler hasn’t done anything for me ha..
    Same TB used on stingray and Z06 and scaler is different even then
    14 Gen 5 Viper
    Mar 2010
    Texas Hill Country
    3,299
    Im running the NW 103 on a whipple and putting any value into the ETC scalar doesn't seem to change anything.
    Apr 2007
    1,104
    that is what I am finding. Got the deer in the headlights look from MSD on this as well.
    Apr 2007
    1,104
    So, really dumb question.
    No transient tab under fuel for the Camaro stuff? For the volume change. Can not find this single cell for the life of me and I have been all over the map. Was it removed? I know the earlier GDI trucks had it.
    Aug 2009
    Calibrating
    3,378
    Don’t recall what it’s under off the top of my head but it’s in there under manifold volume (factory c7 Intake iis around 12.x I believe and truck intake around 14.x??)
    14 Gen 5 Viper
    Aug 2009
    Calibrating
    3,378
    Just seen your reply.. I have a few 18 lt4 files and I’m 90% sure there in there Bc I change manifold volume on ported blowers
    14 Gen 5 Viper
    Apr 2007
    1,104
    Either im blind, or it's not in 4.0.12 for the truck, camaro, or vette.
    Updated to latest "stable" version. not in their either. Been up, up, down, down, left, right, left, right. Found A, can't find B.
    Aug 2018
    12
    I have the same question about the MSD manifold volume. its located airflow-Speed density-dynamic airflow. what number has produced the best results and how does this effect MAF tuning?
    Tuner Camaro6's Avatar
    Jun 2018
    Chicagoland
    137
    Sounds like you are having a transient fueling issue??
    There are a few transient type of parameters based on rpm. The more pressure, the more fuel you will get on a DI engine. The injector is opening the same amount regardless is what I found on Gen V. Steady state driving one fuel pressure, transient increase fuel pressure x amount to suffice what you need for the extra fueling at the given rpm. If certain VE area only, up the pressure based on rpm and airmass vs just the rpm.
    My LT1 with LT4 S/C I had lean transient condition even after VE table was great. It would be 3-5% lean and do this no matter what until about 3,200rpm and be fine after that. Changed two parameters a little bit and perfect. I actually run a slightly modified LT4 VE and coefficients table to mimic the LT4 setup for correct VE vs MAF calculations. The Gen V has so many great features within the ecm.
    If you're moving that much more airflow, make sure to up the values in engine diag to allow for this and not trigger the check engine light.
    2018 Camaro SS, LT4 Fuel System, LT4 S/C
    2020 Ford Edge ST (93-E85 flex fuel tune)
    1999 Pontiac Firehawk
    1987 Chevy Caprice, 6.0L TT 4L80 AWD
    ***Only AWD box chevy in the world***
    Next Level Tuning and Performance
    Tuning email: [email protected]
    Tuner JnJSpdShop's Avatar
    Aug 2005
    Western New York
    195
    Quote Originally Posted by Camaro6 View Post
    SIDI engines don't have transient fueling because you aren't dealing with wall wetting of the intake/cylinder head runner. The fuel goes directly into the chamber
    Western New York's Performance Headquarters
    716.830.0506
    Jun 2018
    Chicagoland
    137
    Quote Originally Posted by JnJSpdShop View Post
    I know your reply is old, but just noticed it when I was looking something up on here. Wanted to reply so others would know. They do in-fact do have transient fueling for closed loop and open loop fueling if you look hard enough.
