Results 1 to 11 of 11
Thread: ISO 1996 Dodge Dakota 5.2L Tune File
    Dec 2014
    Palmetto, FL
    874
    Hello all,
    I am looking for a stock file for a 1996 Dodge Dakota 5.2L V8.
    Aug 2020
    I have a stock 99 Dodge Dakota 5.2 file
    Dec 2014
    Palmetto, FL
    874
    If you don't mind sharing it, I would greatly appreciate it.
    Mar 2021
    8
    trooperstang any chance i could get this file please ? i cant not find it anyway
    Tuner in Training GaS Engines's Avatar
    Jan 2021
    48
    I have a 97 Dakota 4x4 5.2L Sport stock file
    2013 Charger R/T - 1-3/4'' Longtubes, Catless Mids, 180 T-Stat, CAI, 6.4 Manifold Swap, 370whp@5600/411wtq@3950
    Contact [email protected] for Engine Building or Tuning needs!
    Jan 2021
    48
    I hope they're the same. I know body style changed but I don't think anything else did.
    1997 Dakota 5.2 V8 - Stock.hpt
    Mar 2021
    8
    thanks man ... any chance you would know if its possible to make a tune to work on a 2001 dodge dakota that i want to swap over to 5.2 the truck is currently a 2.5 5 speed and i want to put in a 95 5.2 from a dakta and keep it 5 speed with a
    nv3500
    Jan 2021
    48
    Well, I don't know if that file will work without some modification. The file I posted is an automatic transmission (44RE), you would really need a file from a manual truck with the 5.2L or somehow stitch the two together and I don't think that's really possible.
    Mar 2021
    8
    could i use a r/t tune and change the sensor on my engine and try to trick the ecm that its a 5.9 and then just set the main components to what the stock 5.2 tune requires ?
    Mar 2021
    8
    from what im being told by others on forums i cant tune it to work at all even if i use a 5.9 tune and run it that way i was hoping to be able to flash my stock jtec 2.5 pcm and put in a 5.9 rt tune since those came 2wd 5 speed but once again in those forums they say no tune even a ram 5.9 or 5.2 ecm will let this work
    Mar 2021
    Michigan
    3
    DId you find what you needed? I have a 96 5.2 with a manual 2wd 1996 Dodge Dakota 5.2 Manual.hpt
