Thread: Highway Cruise Timing---How Much?
    Advanced Tuner coachcrow56's Avatar
    Dec 2004
    Longview, Texas
    305
    I have read lots of posts as to how much timing you should run on the highway in a 3800 GTP. It varies anywhere from 50 degrees to 42. There has to be a sweet spot somewhere between too little and too much. What do you guys recommend?
    2.8/3.0/3.2 Pulley/ZZP CAI/1.6 HS Rockers/Hi Energy Comp Cam 76-802-9/LS7 Lifters/ZZP Stage 2 Intercooler/TOG Headers/Triple Edge Performance Stage 3 Transmission/3.29 Ratio/NGK TR6ix IRIDIUM .40 GAP/ZZP Fuel Rails/ZEX 100 shot NOS/GMPP Sway Bars/KYB Adjustable Struts/Power Stop Performance Pads/Rotors
    13,559
    Around 40-43 or so should be fine.
    Dec 2004
    Longview, Texas
    305
    One thing I discovered while tinkering with my Cruise Timing, if you don't Disable the EGR Diagnostics, it will add 6 degrees of Timing to your Cruise Timing. I had mine set to 42 degrees, and I kept getting 48 to 49 when I scanned the car. Never to old to learn a few new tricks.
    Advanced Tuner ZeroBoostBuick's Avatar
    Aug 2008
    S.W. Ontario Canada
    322
    Thanks for the info... I knew the extra cruising timing was related to the EGR, but never thought of turning of it's diagnostics.
    Cars I've had ran anywhere from 42 to 50 timing at cruising.
