Results 1 to 4 of 4
Thread: Gong from 2 BAR OS to 3 BAR OS
    Advanced Tuner Pulse_GTO's Avatar
    Apr 2008
    329
    I have a 2004 GTO with the P59 computer. It currently has a 2 BAR OS. If I want to change to a 3 BAR OS, would I have to first Write Entire the stock OS file, then Write Entire the 3 BAR OS file?
    Or would I simply take my stock OS file, apply the 3 BAR OS modification, save the file with a new name and Write Entire from 2 BAR OS to 3 BAR OS?
    13,564
    I always flash back to stock. I don't think you can flash a upgraded OS over an upgraded OS.
    Apr 2008
    329
    Ok, so I went back to stock and then flashed the new custom OS. This time I had to turn off VATS to keep the car running. Did I do something wrong?
    13,564
    No, that can happen.
    If you did a security relearn the VATS disable may not have been required. I tend to disable it a lot of older cars because I don't trust the keys.
