Results 1 to 2 of 2
Thread: vin programming
    Aug 2020
    1
    vin programming
    Hello,
    Vehicle info:
    2019 Chevy Express Van 4500 cutaway L96 6.0L gasoline
    I have put a new ECM got from GM.
    When I check for DTC I have "P0630 - Vin not programmed or Mismatch -engine control module (ECM)" code.
    And when I read vehicle it's says that there is no vin. so I wrote down the vin and proceed.
    When I check Edit -> Calibration Details -> Tune Overview : I can see the correct vin number.
    but on Edit -> Calibration Details -> Controllers : instead of the vin number there is yyyyyyyyyyyyyy...
    I found change vin on VCM Scanner ->Vehicle Control & Special Functions. But when I do change vin it says "vin change failed".
    Does someone know why it does that? and how to change vin please.
    Thank you.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,273
    You'll need to have GM program the new ecm with the vin number.
