Results 1 to 6 of 6
Thread: 05 TT GTO intermittent stumble/ dying
    Aug 2018
    9
    got a fresh TT build currently being tuned and I'm having issues with it stumbling at idle and sometimes dying also have issues when accelerating it just shut all engine power off then back on and it will buck ... also if u get a pull in and coastdown it will try to die as well... anyone got any ideas please let me know . Car does have a scaled tune with ID1700X injectors and an e40 ecm.. everything is new in the car except ecm and harness and tb
    Mar 2011
    Ripley, MS
    1,865
    If you'll post your tune, we can help you with it.
    Aug 2018
    9
    Noone ?
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,459
    P0101, 102, 103 need to be "mil on first error", not no mil . I have never seen base running airflow all one number.
    2013 Silverado 5.3, 6L80k 8.8
    7,640
    Not properly in speed density - DTCs are set to 'no MIL light', should be 'MIL on first error'. Log shows no MAF DTCs set.
    You have the catalyst test disabled, but post O2 test still enabled? Why?
    I have never seen a tune scaled the way this one is. I am not a scaling expert but I do know that 2.18 X 63.492 does not = anything close to the flow rate ID's posted .xls file shows for those injectors.
    Also, the log file I looked at is TWENTY SEVEN MINUTES LONG. In the future, can you please snip it down to show a section, preferably like 30 seconds or so, where it shows the problem happening?
    Aug 2020
    29
    Check under Idle, Airflow, Effective Area-
    Double the Percent Max Values and see if that helps with your idle.
