Results 1 to 7 of 7
Thread: 2005 Gen 3 Hemi super rich
    this is a 2005 Ram hemi swap with a 268 Comp cams cam. super rich on Open loop. I'm in the 8-9 range and was even seeing misfires while running a dune hill last weekend. still insecure about how to lean in this program. any safe easy ways to walk this in a few percent?
    thanks for any help
    Nov 2009
    All Around
    3,149
    you will need to post a data log
    FTW original v1.hpt
    I will post a scan when i get back to my laptop tonight.
    here is a short scan. I don't have the Wideband connected to scanner but when it goes WOT into open loop the meter drops below 10-1 (my wideband reads 10-20)
    Nov 2009
    All Around
    3,149
    ^did you use the file i posted above?
    Sorry Sultan, I did not realize you posted a file. i thought that was just a quote of my file. I will check it out, Thanks
    Advanced Tuner PurpleRam's Avatar
    Aug 2017
    Quakertown PA
    478
    SO how's it working now ? curious I have the same cam in my 2004.
    04 GTX........ 8.91@151mph 392Ci G3Hemi NA 3600lbs 2.6HP/CI Naturally Aspirated
    05 GTxtreme 9:45@142mph 426Ci G3Hemi NA 4000lbs
    G3 Hemi Videos
    https://www.youtube.com/channel/UClS...5mXdDR5sOxs10Q
