Results 1 to 8 of 8
Thread: l76 swapped silverado fueling issue around 4k
    Dec 2019
    5
    Lightbulb l76 swapped silverado fueling issue around 4k
    hello everyone,
    long time lurker,first time poster. I am having an issue getting fuel above 4k rpms no matter what i adjust, i have attached a copy of my current tune and two log files of the issue any help or direction is greatly appreciated.....
    specs below...
    l76 6.0 swapped silverado crank wheel swapped to 24x dod delete vvt delete
    mild pnp heads
    95mm throttle body
    btr stage 3 truck cam lsa 110* 268/264 .553 lift
    short headers
    intake
    5 speed swap
    any help is greatly appreciated thanks in advance guys
    tune
    https://drive.google.com/file/d/1e42...ew?usp=sharing
    log
    https://drive.google.com/file/d/1NJM...ew?usp=sharing
    log2
    https://drive.google.com/file/d/1SgM...ew?usp=sharing
    13,564
    I have a lot of questions here.
    What happened to your VE table and MAF curve??
    What injectors are you running and what is your fuel pressure?
    Something has to be screwed up there because your VE table is about 400% too high.
    Dec 2019
    5
    Hello and thanks for the reply... these are the stock injectors from an lq4 in the square port L76 manifold....... I have been adding fuel to the ve table and maf in an attempt to get the truck to fuel above 4k, truck runs pretty well besides two issues, sometimes i have a heavy bog/stall on clutch out in first or second gear, that and the fueling issue......
    Dec 2019
    5
    and for fuel pressure i have about 55psi....im running the stock lq4 fuel rail and fpr on the l76 manifold....
    13,564
    Those injectors are too small for the power this engine can make. You aren't logging your injector data and that is probably through the roof.
    Are you running the LQ4 MAF sensor and LQ4 MAP sensor or are those different??
    The VE if everything is working correctly should really never see values over 100 in a NA engine.
    I would honestly start over the stock OS and not the 1 bar MAF enhanced. See if going back to the stock OS works better than the 1 bar MAF tune. The 1 bar tune has no real benefit at all. The only one worth doing on this computer is the speed density enhanced OS because it removes the secondary VE table.
    Dec 2019
    5
    yes i am running the lq4 maf and map, thnak you for the tip on the ve table, i have been just adding and adding trying to get a positive result..... i will try to go back to the speed density enhanced this weekend and let you know how it goes, really appreciate your response, thanks again!
    Dec 2019
    5
    so i may have found part of the problem, last night i tried to switch back to the stock OS and i cannot get the program to populate anything into the OS window? i tried resetting my truck, my laptop, i tried connecting through scanner and then disconnecting to try to stimulate the population of the OS menu but still nothing......am i missing something here?
    7,605
    You can't 'un-convert' an already-converted file, you have to go back to a file from before the OS change was applied.
