Results 1 to 7 of 7
Thread: question about MAP and Spark
    Aug 2020
    20
    I have a really basic question. Trying to understand what the car is doing doing during these these drops in MAP & Spark(See Attachment). Trying to learn but there does not seem to be a lot of good content on how to read the scans. Any suggestions for learning would be great!
    28,268
    my guess would be DFCO or AFM
    Aug 2020
    20
    I have disabled DOD already.
    13,565
    Could you post the log here?
    Aug 2020
    20
    Logs
    08072020WOT.hplKuperTuneCamaroSSL99_1.1.hpt
    Attached logs and current tune with DOD delete and CAT delete.
    13,565
    I think I agree with Bill, looks like decel fuel cut-off being enabled when you coast for a few seconds. It shuts off fuel and timing goes way down.
    You also forget to disable the cat test in the engine diag's exhaust tab and forgot to disable COT in the tune. You should also go through the DTC's list and disable all the rear o2 sensor codes because you may get some of those with the cats removed.
    Aug 2020
    20
    thanks for the suggestions! THE COT is pretty straight forward. I have been reading on DFCO looks like about 50/50 in terms of disabling. Looks like there are several ways of disabling also. Some people mention likeing the poping/crackling noise it causes but i have not noticed that. Any advice on how to disable and pros/cons?
