Results 1 to 3 of 3
Thread: Injector pulse jumps to 499ms at fire up
    Jul 2020
    5
    Can anyone tell me why my injector pulse goes up to 499ms as soon as my engine fires up? Floods out immediately with plugs soaked with gas
    Stock tune with vats removed, converted to cable throttle, tables adjusted for injectors. I also bumped up the injector flow rate 25% higher, because it wouldnt even fire at the correct rate.
    Lq4
    milled 317 heads
    Texas speed 228r cam
    50lb delphi flex fuel injectors
    long tubes
    13,565
    Post the tune.
    Do not put the wrong data in for the injectors, they are set and forget table.
    Jul 2020
    5
    Here is the tune. With the correct injector flow rate.
