Results 1 to 6 of 6
Thread: Help Factory 5 with Ls1 no power enrichment
    Hello I have here a Factory five with 2002 corvette ls1.
    does no power enrichment.
    I can not find the problem .I hope someone can help me!!!!!!
    Sep 2017
    736
    Try enable torque at 50%
    1997 30th SS. Torqhead 24x, TFS heads, 223/235 cam, 4l80e, S60 D1SC 14psi
    okay that try thanks
    is enable torq the same as engine load in vcm scanner ????
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,459
    Engine--Power Enrichment__Enable and look down about 3 places
    2013 Silverado 5.3, 6L80k 8.8
    okay thanks for help comandet Afr is now on 12.5
    the current afr is still at 14.5 will now tune the MAF
    thanks
    13,564
    Try to tune both the MAF and VE.
    And make sure you are running 58psi of fuel pressure.
