Results 1 to 4 of 4
Thread: Trying to dial in my tune. 04 Supercharged 4.0 Jeep LJ
    Will someone checkout my tune and log.04 Supercharged 4.0 Wrangler
    Here is my current tune file and last drive with scanner, which wasnt far. I have tried everything I can think of to make it go in to open loop as soon as it shows boost(54kpa is koeo map). I am now having an issue where when the ac kicks on, the idle drops low then kicks it off. It also is hanging rpms about 1200 until I come to a complete stop for a second or so. Let me know if you see anything obvious.
    How can I force open loop instantly?
    What is causing the new ac idle dip?
    What causes the idle to hang?
    This is the only vehicle I have ever attempted to tune. Thanks in advance
    2004 jeep LJ
    Stock supercharged 4.0, 36lb injectors, 62mm bbk throttle body.
    2017 f250 6.7 Diesel
    2020 Explorer 2.3 ecoboost
    2004 jeep LJ
    Jan 2020
    Yuma ,AZ
    103
    you have your closed loop disable at 5300 try 2000 rpm
    Quote Originally Posted by Omunoz View Post
    I will give that a shot. I also lowered the threshold to 54kpa as well.
