Results 1 to 3 of 3
Thread: Lean tip in on cold start 2013 ZL1
    Jan 2020
    39
    A customer brought me a 2013 ZL1 with cheap TLF 90lb injectors. Look like decapped Mustang V6 3.7 injectors. Regardless they work well enough but I'm having an issue with lean tip in on cold start. Warm it's fine. It'll stumble significantly for a couple seconds when attempting to rev or take off with 10-20% throttle. This clears up after a 15-45 seconds and the issue can no longer be replicated until it sits for a while. Fuel pressure is fine, car is still on the MAF and nothing is indicating why this should be happening. I assume it's related to an injector parameter. Any guidance as to where I can start to solve this issue?
    Aug 2018
    289
    Is it still in open loop when this happens, or has it transitioned into CL? If still in OL, maybe it can be fixed in the OL tables. Otherwise, it's maybe just a side-effect of the cheap injectors at low pulsewidth?
    Advanced Tuner jsllc's Avatar
    Sep 2015
    Bozeman, MT
    701
    need a log. anything without data is just guess work.
    2012 ZL1 - Maggie Heartbeat, Port & Polish Heads, Custom Cam, Custom rotating assembly, steel sleeved LS9, No NOS and No water meth. 16psi
    810rwhp and 820rwtq 91 Octane 6400 rpm
    948rwhp and 951rwtq 105 Octane 6400 rpm
    999rwhp and 997rwtq on 60% Ethanol 6400 rpm
