e40 ecm going into rep sometimes at idle sometimes at wot. no cels as most all codes are set to no error reported. Build is 6 years or so old but didnt start this til I updated from like 2.6 lol
Without a code, not sure how we can help you figure out the fault it's giving.
3.59:1 1st gear? What trans is that?
I was hoping someone could look at the tune and find a common issue that causes this issue
Ive been through all the settings and made the assumed proper changes..... the gear ratio was incorrect as it was supposed to be 3.059 so thanks there. As far as someone driving over to look into something ... no... I would like someone to give a quick once over to see if everything looks to be ok as far as the typical things that cause these discrepancies. I guess ill renable the cel and see if I get a code to pop up.. I would think if no cel though there should be a rep but I thought wrong obviously...smh
