Results 1 to 2 of 2
Thread: Confused with my tuning efforts in SD mode
    Aug 2009
    27
    I finally got around to starting my SD tune ad my first impression so far is that driving off the VE tables is so much better than, drivability wise, what i was seeing with the MAF. However, I'm running into two weird issues.
    First issue: I've done two runs so far and Ive done the Multiply by % each time but the error between the first and second log run was even larger. Ive posted the run files below if that helps.
    Second Issue: When i make changes to the tune after doing a log run, the car wont run. It'll turn over, start and then immediately shut down. I've found, however, that if i load the old MAF tune, start the car and THEN load the new SD tune the car will start up with no issues.
    Any thoughts?sd1.hplsd2.hpl
    Oct 2004
    Huntingtown, MD
    200
    Post the two tunes.
    Phil K.
    02 Camaro SS 5.7L LS1
    01 Silverado 1500HD 6.0L LQ4 4L80E 78/75 turbo with Flex Fuel
