Results 1 to 14 of 14
Thread: Who can solve my 10 year no-start problem? I have data!
    Aug 2020
    Ohio
    8
    Always started instantly until one day it wouldn't.
    I've replaced every sensor on the car. Bought HP Tuners hoping I could figure it out. Here's a short file of my crank & no-start.
    Help!
    I've had this car 20 years and it been sitting for 10.
    no start issue.hpl
    Aug 2009
    Calibrating
    3,376
    Have you checked fuel pressure?? Always go back to the basics, never just start throwing parts and replace sensors without prior knowledge
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Aug 2020
    Ohio
    8
    New pump 10 years ago and brand new pump last week.
    I've been through air/fuel/spark with this thing 100 times over the last decade.
    65# at the schrader valve.
    why is your intake temp -38?
    Have 12v at the coils and injectors? Spark?
    Jun 2015
    253
    you need to log a bunch more stuff, so we can try to figure out what is going on. also you should post up a tune
    Aug 2020
    Ohio
    8
    Quote Originally Posted by Just Chuck View Post
    I have spark. It backfired a fire ball out of the intake on starting fluid.
    No clue on the intake temp. Is that sensor bad? Would that lean out the fuel?
    Aug 2020
    Ohio
    8
    Quote Originally Posted by ryan_axberg View Post
    I was afraid to crank too long and overheat the starter. What more should I do? I'm using a new 0411 PCM with the stock 98 Z28 tune. I also compared a base 98 z28 tune from the repository and copied it. Nothing changes.
    Aug 2020
    Ohio
    8
    1998 Camaro Stock Tune- start up tune.hpt
    Here's the tune I'm using
    Aug 2020
    Ohio
    8
    1998 CAMARO NO START LOG 2.hpl
    Here's the recent scan with a borrowed lid and sensor. Still says -38 degrees.
    Aug 2020
    Ohio
    8
    More info on the car:
    SLP Lid
    160 stat
    MS3 cam
    springs & hardened rods
    Longtubes
    ORY
    A4/3.23
    13,576
    The IAT reading -38 means it's either unplugged or it failed and defaulted to the lowest temp. It shouldn't cause it to not start but it won't run correctly when it does fire up.
    Has any of the harness been touched?
    Like is it possible the injectors or coil harness is plugged into the wrong side?
    Aug 2020
    Ohio
    8
    The harness was just repined for the 0411 PCM. I suppose anything is possible. I double checked the pin locations like 40 times.
    Dec 2018
    8
    Have you tested the ecm to make sure its not blown? Maybe swap out for a junkyard unit and see if it cranks up?
    2014 Silverado 6.2
    2000 Silverado lq4 swap
    1979 Camaro
    Aug 2020
    4
    Quote Originally Posted by rmw1775 View Post
    Ive had a bad ecm and it sounded like it was trying to fire but nothing.... put a stock ecm in and fired right up.
