Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
Thread: 06 trailblazer ss 4l80e swap help please.
  1. #21
    Jul 2021
    2
    Stuck in 1st issue as well
    Quote Originally Posted by AJK13 View Post
    I fought same issue for months and the issue ended up being a VSS issue. Had to enable VSS in speedometer calibration and set it up like the 08 express van.Attachment 107412
    What year tbss do you have? I?m got 06 with same issue wonder if that will work for me?
  2. #22
    Sep 2012
    6
    Im same problem with 2007 TBSS 4l80 swap, all the swap is done, the harness was wrong and I have to correct the pins, now all is connected as the TB has a oem 4l80e.
    Now my question is what file and OS I need to use for the TCM. I overwrite the parameters with the info of 2007 Suburban, but couldnt do segment swap the OS.
    I need to change the OS to make it work? Right now the 80e is in limb mode in 3rd gear and speedometer is not working.
    Any help will be appreciated.
  3. #23
    May 2006
    Seattle, WA
    539
    No need to change the OS, both vehicles use TCM OS 24235341. You will need to segment swap the Transmission and Trans Diag segments, then change tire size/speedo/etc to match what you have installed. Write Entire for the initial segment changes (likely don't need to but no harm on the T42).
    ~Erik~
    2013 Sonic RS - manual, CGM, 6M, sunroof, mods in process
    2008 TrailBlazer 3SS AWD LS2, loaded, dropped, modded, SE22 Performance tuned. And then some...
    2002 TrailBlazer LT 4WD 4.2L I6, lifted, tires, exhaust, SE22 Performance tuned
  4. #24
    Sep 2012
    6
    Quote Originally Posted by ScarabEpic22 View Post
    That is my problem, I can`t do a semgment swap my TCM OS is 24238660, and not allow this option.
  5. #25
    May 2006
    Seattle, WA
    539
    Quote Originally Posted by DocZ28 View Post
    Ah, my apologies, I looked in my repo and saw 24235341 as the TCM OS, but that file was one I'd already swapped to an 80E. TCM OS 24238660 is the stock 07 TBSS one, I've edited my previous post to correct this.
    Post up your stock file, let me see if I can get it seg swapped for you. If not, you'll need to license the Suburban file (or the 06 TBSS file that's already 80e swapped in this thread). Then Write Entire JUST THE TCM , that will change the TCM OS to 24235341.
    ~Erik~
  6. #26
    Sep 2012
    6
    This is the "stock" file that was in the TBSS, But is not bone stock, It was tuned before.
    PP Trailblazer SS.hpt
  7. #27
    May 2014
    Nashville, Tn
    15
    What was the solution here?
    I have an '07 tbss E67/t42 (12611938 -> 1250241 Speed Density - 2 bar) with the 24238660 Os, but I can't find another tcu tune for the 4l80 segment swap...
  8. #28
    May 2006
    Seattle, WA
    539
    You need to use an 06/07 Suburban or Silverado 80E TCM OS 24235341 and Write Entire it to your TCM.
    Basically for TBSS 4L80E swap:
    06 - use 06/07 Suburban or Silverado 80E TCM OS 24235341, can segment swap as factory OS IDs match.
    07 - use 06/07 Suburban or Silverado 80E TCM OS 24235341, cannot segment swap this as factory OS IDs do not match. Must Write Entire from a licensed file OR flash it outside of HPTuners.
    08 - use 08 Express Van TCM OS 24239927, can segment swap as factory OS IDs match.
    09 - use 09 Express Van TCM OS 24243356, can segment swap as factory OS IDs match. (I haven't tested this one.)
    There are a few base changes that need to be made once the segment swap has been done, like speedo/shift points/tire size, before you start driving it.
    ~Erik~
  9. #29
    Mar 2022
    9
    do you think you could help me seg swap my 07? im running a relay harness at the moment but would like to use an actual 4l80e tune.
  10. #30
    7,619
    Quote Originally Posted by gumby5ohh View Post
    2007 Suburban 3GNGK26K77G211058 6.0 4L80E - TCM OS 24235341.hpt
  11. #31
    Tuner 01 MidMet WS6's Avatar
    Jun 2007
    St Paul, MN
    167
    I am working through the same issue without success.
    07 TBSS with ECM OS: 12611938, TCM 24238660
    I have wrote in the TCM OS 24235341 from a 07 Suburban w/E67 and it is always in 2nd gear, cluster reads 1st all the time and. PRNDL readout in HPTuners is accurate.
    All 06 Silverado's were classic body style with P59 controller (same as the 07 Express). I also tried a stock 08 Express TCM OS 24239927 with the same no comm issue. Not sure where to go from here.
    Stock 07 TBSS tune file.hpt
    TCPbase 07 TBSS, 6.0, 4L80 swap, small cam, headers, no efans.hpt
    01 WS6-M6, PRC Stage 2.5 5.3's, MS4, Kooks 1 3/4", custom built full true duals w/ X-pipe, SLP lid, tuned via HPTuners
  12. #32
    May 2006
    Seattle, WA
    539
    What base T42 80E file did you use? I did a quick compare with the file blindsquirrel posted above and see a handful of differences, especially under the General -> Configuration setting (NSBU and DRI configs plus a few ISS and OSS).
    ~Erik~
  13. #33
