Results 1 to 13 of 13
Thread: VCM Scanner will connect to vehicle but no live data available
    Jan 2020
    14
    I have a 2000 Dodge 2500 4x4 with 5.9L gas jtec+ ecu here that i can open, modify and write files in editor. Can connect to vehicle with scanner, populates vehicle vin and info. Can scan for codes, but it will not Connect when start scan button pressed, no live information provided. Can anyone shed some light. Running newest version. Attached is vcm suite info. VCMSuiteInfo.txt
    28,287
    Update to 4.7 beta and try again.
    Jan 2020
    14
    OK tried using beta and it would give me live data for 02's and tps but that's all any other idea's thanks.
    28,287
    open a support ticket.
    Tuner in Training Tobbe1's Avatar
    Jun 2012
    41
    any news here? same problem on my dodge ram 1500 1996
    Nov 2015
    17
    Same problem here. It will connect to the vehicle (98 Durango) but will not scan.
    V.4.8.7
    Jun 2012
    41
    i have try diffrent ecu one same year ..dont scan and a newer that scanner work, prob a bug fore early jtec 96-98 inst 99 up jtec+ ?
    have a 2001 durango and it scan ok.
    also try a vw and it works.
    Nov 2015
    17
    I tried the current Beta and it just does the same thing as 4.8.7.
    Jun 2012
    41
    Quote Originally Posted by BBR View Post
    yes have try beta to ..still dont show any values
    Jun 2012
    41
    got a 30usd obd reader from amazon ...and it works so a bug/issue on hptuner
    Nov 2015
    17
    Just an update from my issue: You have to use "Vehicle Default" channels and not SAE channels. Works great after I switched and added the high resolution rpm channel.
    Mar 2022
    Worked for me too. Just got HP tuners for my Dodge and had the same issue. Thank you!!!!
    Sep 2018
    Montana
    13
    I have a 96 Ram 1500 with the 5.2 and similar story - I could not record any data. Like suggested above, I added the specific vehicle channels and not SAE channels, and BAM! Everything I wanted to record worked. Thank you!
