2012 Mustang torque control and target n issues
Hi folks still pretty new to this and i have a 2012 mustang gt that is getting stuck in torque control and target n when the vct switches to optimum stability off decel which is causing the spark to bounce around, what i cant figure out is how to fix it do i need to modify my torque values or is this a problem with my distance tables? Any help would be greatly appreciated
Thanks!
Spark bouncing around might be normal with these coyotes lol. Target N occurs during shifts and during decel timing will go up. Timing during WOT is more important and shouldn’t be bouncing around unless you have an issue.
Mine seems to be after decel when returning to idle and the vct switches to optimal stability seems like she has a problem settling down occasionally even causing a stall.
