Results 1 to 3 of 3
Thread: Going to show my ignorance...
    May 2020
    5
    Is a wide band O2 sensor intended to be installed instead of, or in addition to, a narrow band sensor?
    13,557
    Addition.
    If the vehicle didn't come with factory wideband sensors then we install one so we can use it along with the factory narrow bands.
    Weld the bung in before the cat for best results, run the wires into the cabin, setup the gauge and get it working in the HP Tuner logs.
    May 2020
    5
    Thank you Sir.
    I'll reply again when I can't get it working.
