Upgraded the heads/intake to LS3, which required using the LS3 map sensor. The MAP sensor scaling is off. Bosch is horrible at releasing data sheets so currently I have no idea what the MAP sensor range is.
Locally the key on engine off MAP reading is typically 89KPA, with the LS MAP sensor its reading 75KPA.
If I determine the kpa/volt output for the Bosch MAP sensor - is there a method to change the map scale on the VE table?
