Results 1 to 13 of 13
Thread: Can you take a look Mail Order tune
    First time post doing a ls swap for first time also pickup mail order harness and pcm and this is whats installed. with my little knowledge it dose not look to good obviously the car will knot run. barley starts and will die after a few seconds. any help would be appreciated.
    Thanks Casey
    sorry not
    13,533
    You didn't even say anything about the car and what you did to it.
    Hard to know if all the changes made are going to work with what is done to this car.
    To be perfectly honest, that tune looks nearly 100% stock with minimal changes. Pretty much just a VATS delete and not much else.
    Will Do
    The engine is a stock LS1 from an 2000 Camaro SS all new internals to stock specifications the only addition is GM LS1 hot cam part number 12480033 it has hooker short headers.
    It is a engine swap that is in a 1970 corvette
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,424
    Looks like you dont have your intake air temp sensor hooked up
    2013 Silverado 5.3, 6L80k 8.8
    Quote Originally Posted by Lakegoat View Post
    Yes bad sensor new one tomorrow am
    13,533
    Are you not using the MAF sensor either??
    How complete is the exhaust?
    What is your fuel pressure.
    Certain things need to be changed if a MAF sensor is not being used.
    1. yes but the reading im getting is .31 dose not change replaced with a new one same reading. I dont know enough to tell if that is correct or not?
    2. exhaust full to the mufflers.
    3.fuel pressure is 60lb at startup then 50.
    thank you for your help I just dont know what my next step should be.
    13,533
    Check your wiring for the MAF, if the reading is stuck at .31, then there is an issue with the harness somewhere or a fuse.
    Once your get the MAF and IAT working see how your fuel trims look. Right now they are showing super lean but with the issues you have we can't trust those values right now.
    Thank you will do first thing.
    Just retired form work. so with every thing going on i have plenty of time.
    Thanks for your help.
    Oct 2019
    285
    If it's mail-order, tell the vendor it doesnt work and make them fix it. You paid for a working tune, that's what they should provide. You might have to do runs and logs for them, obviously thet don't know how to tune it by osmosis.
    I had one of my YouTube subscribers telling me this same story with a very well known Youtube tuner that he bought one of his tunes.. He sent me his tune the guy did because he couldn't figure out why is AFR was 22-24!. Turns out he's on E85 and the sensor was disabled in the tune. Simple crap sometimes, but he needed to tell the tuner what he did.
    New log files
    Sorry took so long.
    two new log files.
    Mar 2011
    Ripley, MS
    1,865
    Sorry took so long.
    two new log files.
    Your MAP sensor isn't working. It should read around 100kPa with key on/engine off, if you're located close to sea level. On Corvette 9 log, it never moved. On Corvette 10 log, it dropped to 10 kPa and only moved up slightly.
