Results 1 to 4 of 4
Thread: resync
    Sep 2017
    7
    resync
    Ok, here is my dilemma. Just got back my unlocked PCM from you guys, this is the original one from the truck. I had one that worked but PCM problems so took it out. I figured I had to purchase more credits for this PCM even though it was the same truck, so I did. I have the MPVI2 so according to all I have seen I should just have to resync it and all should be good. When I went to resync it said "client version not supported". now what do I do? Emailed back and forth all day today but tried it when I got home and still same thing. It shows on the web site that I have 12 credits but does not sync. Please help, Truck is stuck with stock tune. I was able to read the stock tune but could not write the tune. I question. This is the tune that I used for the other PCM, do I have to do something so It will work for this PCM or not. Still no resync though.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,262
    Client version not supported is most often caused when you are using very old software and trying to "talk" to our server, fix is to update your software.
    Sep 2017
    7
    Thank you, I will try that as soon as I get home.
    Sep 2017
    7
    That did it. Thank you.
