Hello Helpful type people,
I had posted earlier about a problem with the MAP sensor not reading the same as the mechanical boost gauge.
I have tested the MAP sensor with shop air while logging, and while watching the log live, it is accurate, however it appears to jump between 104kpa and the actual value. The Max Value needle on the log gauge shows accurate with the mechanical gauge.
HOWEVER, when you look at the log, or close it then reopen, the max value is not near what it read. This is my problem.
The attached log file shows shop air applied in different ranges. Around 18 minutes, this read 201KPA on the Max value needle, in line with the mechanical gauge at about 14psi. On the log it is showing 152kpa.
I believe the computer is seeing the correct value, but it is not logging the correct value. Perhaps something to do with the apparent jumping between 104kpa and the real value rapidly when it is above 104?
Anyone have any insight?
Here is the setup
Hello,
Have an 04 Silverado 2500
LQ4
SS2
Deka 80's
3 Bar
GT45
test.hpl
