Results 1 to 3 of 3
Thread: Os dbc or dbw
    Feb 2019
    SD
    26
    Os dbc or dbw
    Is there a way to tell if a OS is Drive By Cable or Wire?
    13,565
    Yes.
    View the system options in the systems tab. A 1 in the ETC box means it's DBW.
    Feb 2019
    SD
    26
    That's what I thought, so as long as the pcm has the drivers I could just change that and populate the necessary tables it should work?
