Results 1 to 7 of 7
Thread: Camaro ZL1 17 M6 Violent Shaking Under WOT
    Sep 2020
    3
    Hello all, I recently installed Kook LT headers (2") on my ZL1. But today while driving, I got a flashing CEL under hard acceleration. It usually only happens when the boost gauge goes over the first tick after 0 and there's a really bad shake, like it's misfiring. I have a P0300 Random Misfire code. I'm still on stock tune as well. Would the spark plugs be fouled any? It's not a cracked spark plug or burnt wire. These have happened over the past few months but we've fixed those probems so I'm looking for any suggestions on what it could be.
    Jan 2004
    Columbus, Ohio
    213
    I would try a new set of spark plugs, using plenty of dielectric grease in the coil boot ends.
    2022 Cadillac CT5-V Blackwing (733 whp)
    2022 Cadillac CT4-V Blackwing (716 whp), 10.750 @ 134.77 mph
    2016 Cadillac ATS-Vs (eleven ATS-Vs in the 9s)
    2008 Pontiac G8 (first G8 in the 10s), 10.727 @ 129.87 mph
    2000 Bonneville SSEi (first 3800 Bonneville in the 10s), 10.711 @ 125.71 mph
    1999 Grand Prix GT (first 3800 FWD in the 8s), 8.902 @ 154.90 mph
    1998 Firebird (first 3800 RWD in the 8s), 843 whp, 8.991 @ 152.12 mph
    1998 Grand Prix GTP (first 3800 FWD in the 10s), 9.499 @ 145.13 mph
    Aug 2009
    Calibrating
    3,374
    Scan each cylinder and see!! Could be just a bad Or cracked plug
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Sep 2020
    3
    Okay so I ran a log last night and cylinder 5 was misfiring at 50% and above throttle. The plug seems a little fouled. I?m gonna a replace it with a new one and switch the wires between 3 and 5 to see if it?s a problem with that.
    Sep 2020
    3
    It seems as if the car is running to lean? I do have 2" inch long tube headers and catless pipes to cutouts. If anyone can lead me in the right direction on what I should do to my stock tune file, It'd be greatly appreciated
    13,571
    Without a log or a wideband we really have no idea if it's running lean. You own the car so that is something you need to figure out.
    And or inspect the rest of the spark plugs and wires for damage as well as checking for exhaust leaks.
    May 2003
    South FL
    1,375
    Get the car on the dyno with a wideband or install a wideband in the car and tune it properly. If it's running lean enough to violently shake you're going to break something. But I doubt its running that lean. It's more likely you have bad plug wires and/or a damaged plug. I always install new MSD wires or equivalent with header installs. I also remove the plugs before removing the old manifolds and put them back is after the headers are installed and bolted down. Its very easy to damage stock plug wires when removing if you dont use the proper tool and its almost guaranteed that you will damage a plug if you dont remove them when installing headers.
    [email protected]
    Owner/GM Calibrator
