Results 1 to 3 of 3
Thread: 4l60e trans tuning with vette servo
    Aug 2020
    48
    before i had the servo installed i used russ k guide to better shifts.i returned the trans tables to my stock file.i installed the vette servo...shift firmness seems good to me but what else should i change to adjust for the servo?
    13,533
    You don't have to change anything. The servo is a physical part that is already changing the way the transmission worked.
    It's up to personal preference now on how you want it to shift and when.
    Aug 2020
    48
    So when i increase part throttle rpm shifts upshift and downshift nothing else has to be changed
