with the pro cable an features.. anyone setup using this unit? would like to install an use the 2 analog wires on the prolink cable. \DLG-1: Dual Lambda (Air/Fuel Ratio) Gauge
(Includes: Bosch LSU 4.9 sensors)
the document form innovate states about settings..
The default analog outputs are as follows: Analog output one (Yellow) is 0V =
7.35 AFR and 5V = 22.39 AFR. Analog output two (LC-2?s Brown) is 1.1V =
14 AFR and .1V = 15 AFR. Note: The DLG-1 and LC-2?s ground should
share the same grounding source as the device to which you are feeding the
analog outputs, the easiest wait to accomplish this is to run an aux ground
wire from the ground point of the DLG-1 and LC-2 to the ground or signal
ground of the device you are interfacing with.
also states Factory Programmed Default:
The analog output by default is programmed to output between 0V at 7.35
AFR to 5.0V at 22.39 AFR.
look forward to feedback an or success story before i spend the extra cash. was looking at this or the Ballenger unit.![]()
