Page 10 of 26 FirstFirst ... 6789101112131420 ... LastLast
Results 181 to 200 of 520
Thread: lean area around 2500ish rpms-2014 ctsv
  1. #181
    Advanced Tuner JayRolla's Avatar
    Mar 2021
    206
    Quote Originally Posted by sgod1100 View Post
    Cool, let us know if you get anywhere. thanks. I remember asking Pat G about this problem a few years ago and he mentioned that my "coeffcients" have to be tuned. Now I'm not sure if he was referring to VVE coeffcients or the prediction coefficients. From what I've read though the prediction coefficients can't be tuned.
    I do see you can adjust them under Engine>Airflow>Dynamic>Prediction Coefficients.
    2013 CTS-V Coupe M6 - 1 7/8" Headers, 3" x-pipe, stock mufflers, Airaid intake w/green filter, ID1050X injectors, DSXtuning flex fuel kit, DMS under hood tank, upgraded pump, 3/4" lines, griptec 2.4" pulley, solid isolator, 100mm idler, reinforced brick, MM mild catch can, AEM 30-0334 wbo2, 600whp/630wtq
  2. #182
    Feb 2018
    824
    Quote Originally Posted by JayRolla View Post
    Yeah, you can adjust them all you want, but actually dialing them in correctly for your specific setup is what i'm referring to. When they are left at the stock values you will not hit your commanded afr while being below the dyn air rpm cut-off, you will be lean. I've got logs showing just that
  3. #183
    Aug 2018
    294
    Zeroing the prediction coefficients definitely fixed some odd stuff on my LSA car.
  4. #184
    Mar 2021
    206
    Quote Originally Posted by RobZL1 View Post
    I just zeroed them out and it had no change on our lean spike issue. But I was now getting a super rich spike at heavy to max throttle. Would richen to .65 EQ and then to my commanded .80 causing a major loss of power till it corrected. Added back the table data and issue fixed.
  5. #185
    Tuning Addict
    6,813
    I'm pretty sure there are more tables that work in unison to the prediction coefficients that we don't have access to. Instead of zeroing them I would suggest using other cals tables such as a ls9 or ls3's then testing. I futher don't believe these to be the problem - I'm sticking with a functionality or rationality check taking place that the bigger injectors are throwing off...
    ~Greg Huggins~
  6. #186
    Mar 2021
    206
    I looked at those and the LS9 are the same as the LSA. So I tried to zero them out to see what would happen and had a negative result. I somewhat have a slightly leaner EQ, by maybe .01-.02 than my commanded AFR before dynamic disable but nothing bad like sgod was referring too. Really strange the auto's dont seem to do it when in when TUTD is disabled.
  7. #187
    Feb 2018
    824
    Yeah the prediction coefficients have no effect on our lean issue from my experience. I have had mine zero'd out and I've never ran into a super rich spike during heave accel.
  8. #188
    Tuning Addict
    6,813
    I even discussed it with PGA2B where I wondered if the engineer writing the cal got lazy and didn't fix where the ctsv's didn't have the exhaust valves in the mufflers that would open and close to allow bypass like the ZL's do. Those on the ZL would open right around 2500 to 2800 rpms and if they were unplugged and not just unhooked via the vacuum line and capped off that way - they would go into some sort of weird reduced power mode and stumble right around that rpm area - might be why I've never noticed it as on every single one I tuned - unless it was a minor cai modded zl - I unhooked and capped off the vacuum line. So if said engineer got lazy and just threw the zL's cal into the ctsv - then that might explain some things. However I don't remember if you can technically read out the FULL calibration including the exhaust controls to see if it's active now or not? It should be in the chassis control module if it's like the newer stuff.
    Just grasping at straws at this point as I'm almost positive it's a rationality check and something isn't working right.
    ~Greg Huggins~
  9. #189
    Mar 2021
    206
    That's interesting.
  10. #190
    Feb 2018
    824
    Sooooo. anyone else with an abnormally large brain have any other suggestions????
  11. #191
    Mar 2021
    206
    So the new injectors have the same issue I'm guessing. I've been poking around changing random stuff and nothing has an affect. I don't see what else we can try and it's driving me crazy.
  12. #192
    Feb 2018
    824
    That's correct, same thing. Honestly not AS bad (I don't feel it as much which is good), but I can still see it on the logs. Yeah, me too.. drives me nuts as well
  13. #193
    Mar 2021
    206
    I decided to start my VVE table over fresh from stock and instead of tuning via wbo2 error I did the LTFT method. It didnt create the large spikes at 1600 and 2600 as much. It feels a lot better but I still see the lean spikes and can slightly feel them more depending on throttle percentage. Also ramping in PE faster helps for the harder throttles since it richens a lot quicker. I do notice if I am in like 6th gear on the highway and I hold it right at 2600rpms it does kind of stay pretty lean, jumping between 1.00 to 1.07 EQ ratio.
  14. #194
    Feb 2018
    824
    If you are running a CL tune (which most of us are) you shouldn't be tuning the closed loop areas with the WB. WB should be used for OL only (as we don't have any other choice). Your NBs are going to be doing the corrections when you are driving around so you want use those (I like using STFT and have my LTFTs turned off). Yeah, if you are on the highway and go through that 2600 rpm zone it will have a long hump in the afr error graph.
  15. #195
    Aug 2020
    335
    Throwing out a thought because it seems similar and you are talking about the prediction coefficients now.
    It could be something related to a max VE setting or something. The E40s have a table for that in dynamic airflow and it shows as a lean spot in the scanner if the table is not adjusted. Though with the later VVE stuff, they very well could have eliminated that type of thing entirely. Dynamic airflow has always been mapped out similar in hp tuners over many different GM vehicles but not the max VE table. So to me, it seems that the dynamic air calculation was an internal copy pasta at GM with inputs added or subtracted for various different vehicles.
  16. #196
    Feb 2018
    824
    Quote Originally Posted by eXo3901 View Post
    The only thing I see in my tune (E67 Gen4) is "VE Correction factor" table under the Airflow> dynamic tab
  17. #197
    Mar 2021
    206
    Yeah that makes sense. That's how I normally did it. But I tried the wbo2 method to try and get those lean spots taken care of with some additional fuel which didn't do anything really. I might try and disable ltft then just use stft to see how that dials in the vve table but it does seem pretty good using ltft to adjust.
  18. #198
    Feb 2018
    824
    STFT go wayyy faster than LTFTs. Yeah, I had the same plan as you a few years ago-using the WB to see if I correct those lean areas, but it didn't work. Reason I have LTFTs off is because I don't want them to influence my WOT fueling. If you have a "+" LTFT prior to going into WOT/PE that percentage will be added to your PE fueling. Won't be much if you have your tuned dialed in, but I'm OCD..lol
  19. #199
    Mar 2021
    206
    Thats why I always shoot for negative fuel trims slightly. If something goes crazy and they go super lean without me knowing at least it will be safe and add fuel to PE. I sent another email to White just in case he overlooked my 1st email. I think I saw he just had a baby so he might just be taking some time off right now.
  20. #200
    Feb 2018
    824
    ok, cool. Hopefully he will get back to you sooner than later
