Results 1 to 8 of 8
Thread: G8 Knock Sensor Settings
    Im trying to make my Knock sensors a little less sensitive. Ive been reading much on desensitizing them and adjusting attack and decay rate but none of those threads seem to line up with the tables in my tune. Anybody care to help a brother out? Thanks
    What mods do you have? Just curious as to why you feel you need to desensitize them. To do this, you must increase Initial min, and Min Level. What octane you running?
    Cam, rod mod intake. Best I get is 92. Can’t run anything past like 16 degrees WOT without it knocking it down. I did find some answers and did what you said along with other settings. Been adding 1 degree and making a run now. Up to 22 degrees and still making power.
    be careful how much you desensitize, what is your EQ ratio Set to in PE?
    Sep 2019
    6
    Just as a sanity check, the PE equation is 14.7/PE.
    So if you want a 12.4 afr you would use 14.7/12.4=1.185 in the PE table.
    Quote Originally Posted by aharonc View Post
    Yes.
    Calibrator By Day, Student of the Game at Night.
    www.LSXedit.com
    Want to Learn Hands On? I Offer Remote Tuning Email Me at [email protected]
    TEO TUNED
    You Can View Most of my Library on Instagram
    Website Coming Soon...
    INSTAGRAM: @TEOTUNED
    Dec 2018
    20
    Quote Originally Posted by Srblacks13 View Post
    How did you end up doing the knock sensitivity settings?
    1986 GN Stand alone FAST XFI
    1968 Chevelle Turbo LQ4
    2014 Caprice 6.0 6L80
